Hello!
New owner!
OS 1.1.0
So I just started using the PolyPulse tonight and after I got some sounds and rhythms going I slaved it to the Cirklon.
Only running Track 1 and the other four tracks are not active and don’t have sounds assigned to them.
(still learning how to use it) ![]()
It sounds like it is in sync but the display on the PolyPulse keeps running up and down in value like crazy.
I have the Cirklon at 110 BPM and the PolyPulse displays a constant scrolling number running up a few points and then down several points really quickly.
From 110 up to 110.9 the down to 109.1.
At least that’s kinda what it looks like.
It does this when at any tempo I set.
I saw in the Setting of the PolyPulse that the PPQN is at 4.
(not sure if that was the default)
I messed with that a bit but the clock display still acts the same.
Thanks for any help!
