Would it be possible to add the Polypulse audio Inputs as triggers for the Ducker FX ?
Meaning, if for example you use Track1 with Polypulse audio IN1 routed to any output, would it be possible to have that same IN1 available as a trigger in the Ducker FX triggers list (Ducker FX edit menu)?
Interesting idea!
Do you want to connect something like eurorack triggers to the inputs, or actual audio signals like a synth or drum beat for instance?
For instance I was thinking about actual audio signal (Beat, Synth, or any other kind of audio sources).
But You’re at the better place to optimize the idea of course.
