Wavetable Designer export presets
Wavetable Designer already includes a number of export presets to quickly start create wavetables in a file format for a specific device, but more can be added
If you want an export preset added for another piece of hard- or software, please reply to this thread with the following information:
  • brand and device name
  • file format (.wav or something else?)
  • bit depth (8/16/32?)
  • table size (number of samples per single waveform?)
  • cycles (how many waveforms in wavetable?)
  • any other relevant info? table size in filename?
If you are unsure, post the info that you have and we’ll try and figure it out.
Hi there @ward! Could you add a preset for industrial music electronics eurorack modules(piston honda/kermit mk3)? The specs from the manual are:
1-channel .WAV file, 16 bits, 32Kbytes (256 2-byte samples per waveform. 64 waveforms per file total)
Just added an export preset for this!
Wow thank you! Will grab a license for this. The free WaveEdit is good but this tool seems to have deeper waveshaping options.
A post was merged into an existing topic: Wavetable designer
