Hey all,
Another update is ready!
- added retrigger mode: sync to LFO.
- added walking amount to the random modulator.
- you can now create a template project that is loaded automatically when the PolyPulse firmware starts (by saving a project with the name template in projects/).
- output FX chain now stored in *.proj files.
- fixed bug where chord mode: random note did not work when polyphony was set to 1.
- LFO: reversed square shape so it goes high first and then low.
- resonator: fixed bug where ratchet created audible bugs if noise filt. was set to a low cutoff value.
- filter audio effect now has reso parameter with 0%-100% range instead of peak parameter with 0.2-18 range.
Here is the new firmware: polypulse-firmware-0.1.29.zip (900.0 KB)
Enjoy! ![]()
