Hey all,
Cool new stuff: modulators can now be triggered from other tracks and specific pulses. As an example: a pulse on track 3 can trigger an envelope that modifies the filter on track 2. There is also some practical stuff: you can now MIDI learn triggering a cue, and there is a global pickup mode setting for the volume controls and send controls.
- The modulator trigger system has been overhauled.
- Modulators can now be triggered from one or more of the following trigger sources:
- The start of the current note (used to be trig: note).
- Touchpad (outputs a trigger at the start of touching the touchpad).
- Sequencer reset of one of the 5 tracks.
- Selectable pulse of one of the 5 tracks.
- Press the top-left black numpad button (trig) to select which of the trigger sources listed above triggers the modulator.
- To switch LFO between sync or the new trigger system, hold [shift] and press the top-left black numpad button.
- Cues can now be started using MIDI: each cue can be mapped to a different note on, control change or program change.
- Reduced artifacts when applying fast modulation to volume parameters in sound engines.
- These parameters can now be modulated:
- Equalizer: low gain, mid freq, mid gain, high freq.
- Fade delay: freq, feedback, shift, dry/wet.
- Added send pickup and volume pickup option in [setting]. If enabled the volume/send knob position is read from *.inst files and used until the physical knob is moved to the same position, then the knob controls the volume again.
- Fixed a bug where removing a modulator would not remove any modulators that were assigned to that modulator.
- Fixed MIDI mappings to audio effect and modulator parameters not working.
- Fixed the LEDs not showing the approximate parameter value of envelope/modulator parameters.
Here is the new firmware: polypulse-firmware-0.3.1.zip (986.8 KB)
Enjoy! ![]()
