0.3.6: Fast reverb
Hey all,
A small update with optimizations to reverb and fixed MIDI sync!
  • Reduced CPU usage of reverb:
    • color settings clean/lossy/noisy from 9% to 7.3%.
    • color 14-bit/12-bit from 12% to 7.5%.
  • Added option to change the order audio effects within a track’s FX chain.
  • Added visualization for glitch bits algo.
  • Fixed MIDI in sync not working.
  • Fixed reverb color settings lossy and noisy not working.
  • Fixed reverb filter not working.
Here is the new firmware: polypulse-firmware-0.3.6.zip (1019.4 KB)
Enjoy! :yellow_heart:
Just tested, all is working fine !!! :+1:
Thank you Ward !!
I realized today that this 0.3.5 update broke reverb’s filter parameter and it was a simple fix. As it is the only change, I’ve replaced the 0.3.5 download link with a fixed firmware. (0.3.6)
