Autosave system
A question about autosave.
I d like to tweek a project live and be able to be back to my original for a next gig. If the autosave in on, my “tweeks” will be recorded and save ? Is there a possibility to “lock” a version or shall I disengage autosave during live performance ?
Thank you
The autosave system saves in a folder called backup inside the current project. The current project is unaffected / not overwritten by the autosave system, only the files in the backup subfolder.
You can leave it enabled and whatever is changed will be (auto)saved some time after you stop playing (because it only autosaves while the clock is not running).
Thank you. That’s perfect
