Bug with midi channel and Add notes with midi
When I leave a project and I m back to it
“Add notes with midi” sets itself in “true” and midi channel on All… whatever I do.
I think maybe that is because those parameters are stored in projects, and not globally.
You can set it in the template project if you want to always have specific settings
I did some test and even after saving a project with correct midi channel and add note list, it does come back to “factory”.
F
Ah I found the bug. It is fixed for next update!
Thank you !
That would avoid me some midi loops when I forgot to reset midi channel on start :wink:
