Hi, I mentioned if before but make it official now.
What I would like to see:
I would like to have in the below shown menu, a choice for “replace samples” or “random load” “random replace”.
When having X number of samples inside, you select all or the ones you want to replace with shift and it would replace the selected samples with another one from the same folder.
Why I like to have this:
I am working with percussion loops, tribal loops and also hihats which I create from one shots.
For this I create samples lists with about 4-12 samples in one sequencer line and let them loop through. But not always it sounds good. To save me having to go through all the menus to delete samples from the list, then go to the folder again and add new by scrolling through and having to select myself. Also you dont always scroll completly through and end up always taking the ones in the top half maybe. It would be great ease of workflow and great method to get surprising combinations in a fast and inspiring manner. even just replacing one kick which is no longer fitting the other percussions would be much faster instead of going through the folders.
Thanks
Daniel
