Using the PolyPulse’s keyboard, we can create chords in a note list one note at a time by using the shift key. When I hold the shift key and play notes from an external keyboard one at a time, the notes are inserted serially and not in parallel. If I play a chord on the external keyboard, it inserts correctly as parallel notes of a chord, but I also want to be able to add the chord’s notes one at a time. Is this a bug?
Ah I didn’t think of this while implementing adding notes via MIDI.
In next update you can add notes in parallel to existing notes if you hold down shift, so it works the same for MIDI and the internal keyboard.
