Introducing Wavetable Designer
Hello all,
Wavetable Designer, first shown to the public at Superbooth 2026, is now available online! The new browser based tool allows user to create wavetables for almost any soft- or hardware synthesizer that loads custom wavetables, including the Lambda Synthetics PolyPulse.
Using Wavetable Designer, wavetables are created by a chain of generators: sources add a new waveform and effects modify the signals created by previous generators. To quickly create sonic changes in a wavetable for each parameter a value can be set for the first and last wavetable: all cycles inbetween are generated automatically.
Wavetables are plotted in 2D and 3D and the built-in audio preview allows you to listen to the wavetable at different frequencies and with a moving position while editing. Wavetable Designer exports *.wav or *.wt files at various bit depths.
A short video demo can be found here: https://www.youtube.com/watch?v=b35s70McI-s
Try it out now at wavetabl.es
very nice interface! it feels comfortable and functional. ive been using it for hours now.
Wavetable Designer has also been updated today and a few generators have been added.
It also introduces the blend mode parameter to all source generators. Similar to how in drawing software you can set how a layer is added/mixed with other layers, blend mode determines how the source is added to the existing signals created by sources and effect above/before it. The options are:
  • add: simply mixes/adds, default
  • subtract: mixes/adds inverted
  • multiply: signal of the source is multiplied with the existing signal. Can be used for ring/amp modulation purposes, a sort of envelope or windowing.
  • max: keeps the most positive signal
  • min: keeps the most negative signal
  • fill: keeps the parts of the source that fit between the existing signal and zero.
Hi Ward, the Wavetable Designer worked and made sound but after I authorized it, it still works but stoped making sound. Can you check this please.
Can you try a hard refresh?
Linux/Windows: [ctrl]+[shift]+[R]
Mac: [cmd]+[shift]+[R]
That clears the cache and all resources used by Wavetable Designers will be loaded fresh.
Thanks for your reply. I had the exact same problem after rebooting and the hard refresh did also not help. But now it works again, although I cannot say what resolved the problem :zany_face:
wow best wavetable creator evar!
