After rebooting the Polypulse; “Midi IN” for each track (1-5) doesn’t respond to external MIDI messages/notes. Obliged to reset to “true” in Track edit menu to recover MIDI communication.
While on firmware 0.1.30, try setting MIDI note in = true and then saving the project with “overwrite.” When I do that, the MIDI note in setting persists across reboots.
I’ll try it, i’am actually on 0.1.29 firmware.
Thank you !
Ok, in fact MIDI IN is working fine after rebooting the Polypulse. Except the Track led (right next to the track button) that don’t blink after reboot. Obliged to reset “MIDI NOTE IN” to “flase > true” (in track edit menu) to restore the led blinking.
The LED (and the MIDI input actually) works again once any setting in the track settings menu has been changed.
I fixed it for next update!
