Having the recorded movements to a track‘s square pad it would be great for modular to assign to 2 Outputs with selectable VOLTAGE ±5V, or 0 to 10 / 8 V ( or on realtime movements )
The audio outputs are AC coupled so sending CV signals for modular synths is not possible.
I’m planning on building an ‘external / MIDI / OSC’ type sound engine. The idea is that it can trigger notes on external synths and send parameter values. Then if you want to use it with modular you could connect the MIDI out to a MIDI → CV module.
I think it would be very cool to add this, but it requires a bit of careful design on my end so don’t expect this to be in the next update.
I had imagined /fantasized that the MIDI and Voltage out would be linked to pulses … ; ![]()
a config setting of Internal/MIDI / Gate) per Pulse
All, one or two simuntaniusly= any mix configured by users
So you could layer for exsample: a pulse from track 2 and two pulses from track 3 and set them to the same MIDI channel to get a realative symmetric MIDI output mix
without sacrificing a track
Just makes the MIDI generation more exotic
I think MIDI out is the #1 most desirable feature, by far.
