"Note repeat" for Note list and Sample List
Would be nice to have the function/option to “note repeat” a specific note or sample in note/sample list.
Phohat
So you can already create note repeats when using samples (in quad engine/subtractive and resonator).
In the sample list editor: turn on looping for the sample you want to have repeats and adjust the sample end time to be within 50 - 200 ms of the start time. Make sure the sound engines envelope is long enough to hear the repeats.
In this case the rate at which the sample repeats is linked to the sample pitch which means that the repeat rate can be varied by:
  • changing the rate parameter in the sound engine (through which the repeats can also be changed by the touchpad)
  • setting the sample to pitch tracking and playing different notes
  • shortening the sound engine envelope (temporarily) so the repeats are cut off.
Here you can hear an example where sometimes the snare and hihat repeat using this technique: https://www.youtube.com/watch?v=le7TT2yUk7E&t=310s
Very nice !!
Thank you for the tip !
note repeating a specific note (ratchet) in the note list would be nice, too.
