Output FX removed state not saved in project file
Even if I save my project without any output FX loaded.
They are still loaded after a firmware reboot when I load my project again.
Which means default Output FX state is not registered correctly in the project file or seems to have some kind of independant behaviour.
Ah yes this is indeed a bug, you should be able to save an empty FX chain. I’ve fixed it for next update!
