Is it possible to use the Polypulse audio inputs and Polypulse audio FX live ?
Meaning is it possible to use Polypulse audio Effects as/like external Effects with your mixing board ?
If yes, what is the highest Bit Depth conversion at the Polypulse audio inputs A/D ?
The converter chip can support up to 24-bit data. However due memory bandwidth constraints in the processor and the audio driver it sends/receives 16-bits of data so in practice it is 16-bit.
Theoretically I could try and rewrite the driver to use 24-bit but that would be quite difficult and thus very unlikely to happen if I look at the other things that are on my to-do list.
