I’m not really understanding very much about how to actually use Polypulse so far.
If I want to save a PROJECT, I enter the files menu, and there are 2 folders, samples and sounds. I don’t wan to save my PROJECT into either of these folders. Shouldn’t there be a PROJECTS folder where PROJECTS are saved into?
I feel like it’s going to get really confusing really quickly if I save PROJECTS into the sounds folder?
Another simplyfication for saving would be quite helpful, if I am mangling around and I like what I did, to push just one defined Button ( maybe with Shift)
And bam I would Instantly be able to save that state of work, b4 I have to shut down because someone suddenly needs my full attention
…. and even better if I switch on again after that everything is loaded or easy to reload ( like: „do you want continue with you last state of work?“ and I just push „yes“ b4 anything else)
I hope this makes all sense to you
I’ve connected to my router via an ethernet cable.
I can browse the existing folders on the PP from the PP manager now, but when I click “create folder” - it says that a folder was created, but there is actually no folder created - so I can’t make a “PROJECTS” folder at this time.
[edit] Never mind - I figured it out, I didn’t realize that I had to enter a folder name BEFORE creating the new folder. I get it now! Hahaha
