As I am sitting here with a magnifier to read that Wiki I would be very thankful if anybody could explain how to Route a simpele MONO Signal to the Summing Out.
Press [settings] scroll down to the in x to out chan parameters. They route inputs to throught the main FX chain (by default only a limiter) and to the audio outputs.
For instance, if you want input 3 to go to output 1, set in 3 to out chan to 1.
Right now you can only route a mono input to a single output.
To next update Iām adding the option that you can route an input to a stereo pair. For example: input 4 to output 1+2.
Do you already have a due Date on Hand when the Update is going to be released?
I am preparing some livesets and that would help me so much integrating the Poly.
Can the external Audio than be handled as a sound engine or is it just hard thru?
I intend to release this week if all goes well.
You can also route audio inputs into specific tracks so they are processed by the FX chain of that track. Press [edit]+[track] and then scroll down a bit to the in x to chan parameters.
I was thiinking of somekind of external Engine like the in-machines in the old elektrons (mm/md).
Especially for mangeling the Input.
