"Send" audio signal is mono when stereo's expected
When turning the send knob I see the audio signal outputing from Polypulse modulates on the Left channel only. When if I select “7+8” physical outputs (for my set) in the “settings > routing > send fx routing” menu, it only modulates on 7 output and not both.
The engine used to feed those outputs has 4 voices of polyphony and is mixed to stereo thus I should see a stereo signal modulate on 7+8 Polypulse outputs (in the Output FX peakmeter display).
Fixed for next update!
