When inside the Master FX menu (shift+FX), and once inside then you edit FX (edit+FX) then if you push the “X” encoder instead of rotate it then you’re stucked inside the Master FX menu, impossible to get out because Master FX window is still visible/opened but the menu you’re in from a system point of view is either the Track or pulse menu. You recognize it by the Master FX leds changing/switching to Track/Pulse leds.
It looks like a bug, but maybe i’am wrong…
Happens the same if you push a Track button while you’re inside the Master FX menu in edit FX Mode…
So if you are in the master FX window you can exit that the following ways:
- pressing any of the encoders on the left bank
- pressing [yes]
- pressing a track button
- pressing a button that opens another menu such as [files], [samples], [settings]
However, if you are editing the master FX chain you should not be able to exit the menu. I just checked and in the current firmware (0.1.27) you can indeed get stuck by pressing a track button or encoder.
I’ve included a fix in next firmware update
