Post your questions / discussions / tips and tricks relating to sequencing with the PolyPulse here!
Greetings,
Few questions:
1 - In the Pulse Editor Menu what are the min/max values for the âresetâ paramter ?
2 - In the Track Editor Menu what are the min/max value for the âclock multâ and the âseq resetâ paramters ?
3 - Is there a way to trigger pattern from an external controller (MIDI or OSC) ?
Thank you in advance for the help.
Best,
Phohat
4 - What is the Sequencer Max PPQN resolution ?
I ask because it looks related to the âclock multâ parameter but i am not sure about it.
Thank you,
Best,
Phohat
interval, reset and seq reset are practically unlimited. Their maximum is 2147483648 which is the largest number that can fit into a 32 bit integer.
has a range 1-64. By default it changes in steps of x2 or /2 when changed with the encoder. This can be fun to change it in a âsyncâ feeling way while performing/jamming.
It can also go in steps of 1 if you are looking for a specific value or maybe odd numbers.
Not yet. It is on my todo list (both for MIDI and OSC).
clock mult sets how many clock ticks there are per beat/quarter note (so you could call it the PPQN). It defines grid of a track and the shortest interval between notes.
PPQN as mentioned here Sync with other gear - PolyPulse manual is just to understand sync signals received from other devices. The PolyPulse doesnât really care what PPQN you set when syncing with other devices, as long as it is the same value on both devices.
Hey Ward,
Thank you for that very informative reply.
I know youâre a busy man but I really hope youâll soon find the time to implement MIDI / OSC pattern triggering.
That feature in itself will open a world of possibiliesâŚwhen the Polypulse is used with other gears/controllers.
Best,
Phohat
