Some more requests / user experiences
Some questions / requests :slight_smile:
Would it be possible to morph the delay type ? That would be interesting to have a digital delay at a corner of the touchpad and a bucket brigade at an other.
I imagine that the fx send in only analog : i would have like to “keep in memory” the fx send settings :slight_smile:
I had some trouble with one of my songs ; CPU was ok (about 50-60) but I get difficulties starting the polypulse (1 beat and stop). I realize that I had too much info on the first beat.
I found a way to avoid this hard start by delaying the first beat of one track. (start)
I also have a constant crash on one of my song loading. But it’s a 2 minutes long sample that makes it crash.
If I come from an other song it crashes
When I load just after a powering on (or a crash), it works.
I know the solution is to make my sample shorter… But I just let you know this event.
Thank you, look forward for the new firmware : it will be a new step in composition / workflow
I wrote these on my todo list!
I have also noticed this occasionally I think I know how I can fix it, but I’m not sure if I can do that before next update.
Thanks for letting me know! I also encountered this at Superbooth with a project that had a sample of 3 minutes long. I found that loading the sample list first and then loading the project seemed to work, or that you can restart the firmware (no need to fully power down).
I think I have fixed this (for next update) but I have to test it a bit more to be 100% sure!
The issue with long samples causing crashes has been fixed in 0.3.0: Cue system
There is a new setting (update 0.3.1: MIDI cue trigger) for the volume knobs and send knobs. If you enable pickup the position will be loaded with the project and stay at that value, until you move the volume or send knob to the same position.
You do have to save/overwrite projects again with 0.3.1 for it to work because the volume and send knob position was not saved in *.inst files before now.
Whaoh !
I believed that would not be possible.
It just arrive at a moment where I m working and needed again this feature/
Thank you so much
